Okay - so I was mowing my lawn (actually mowing leaves more than lawn), and I heard a loud pop - sounded like a spring breaking (metal verses hitting a branch or something below the deck) - and then the blades seemed to slow significantly (if they were turning at all). I was afraid to look under the deck while it is running (seems like something someone would do for a Darwin Award).
I stopped the mower, and checked the tensioning of the belt. It seemed looser than before, so I pulled the deck to see if one of the springs on the deck broke that would impact the tensioning, but I didn't see anything obvious. I did notice on the cable from the PTO engagement lever (not sure the real name) and the deck that some of the black outer case had come off, but that didn't seem to be the issue. Could be that the cable stretched somehow? We have a good local shop that has parts - but I am not sure what to ask for as it wasn't something obvious. I did check the blades (just in case I did hit something, but there didn't seem to be any issues with the blades themselves).
Thanks for any help.
