Black Bart
- May 4, 2011
- 15
- 550
I don't know if this helps, but the 10W40 oil I have is almost as clear as water, so does that mean it has little additives in it and is suitable ?
The color tells you absolutely nothing.
What brand of oil is it.
Can you buy SHELL ROTELLA where you live it is a very good HDEO in the USA more than 80 percent of the 18 wheelers on the road use it.
It is recommended by CUMMINS CAT MACK and DETROIT
The only way to check additives is with a UOA and check it for a TBN count but I can assure you ROTELLA has a great add pack including ZDDP at 1200ppm :thumbsup:
