Not true. I don't know exactly what you mean by "shear resistance" (or did you really mean to say "sheer resistance"?) but with multigrade oil, the higher number represents the viscosity at operating temperature, while the lower number is the viscosity at cold cranking temperature, something only of interest when starting a snowblower.
Be that as it may, to achieve the wider viscosity range, the oil either has to be synthetic or have more additives. It's probably distrust of all the additives that has given multigrade oil a bad name. Anyway, if you really want to read debates about oil, go to
- Bob is the Oil Guy and read the forums. Lawnmowers are a relatively low stress, slow speed application and any motor oil will do, within reason. I remember once reading somewhere that 50-weight oil was the best for Briggs & Stratton engines, so I tried it. It worked just fine, but was a ***** to pull-start in the late fall when it was starting to get cold.
