Does anyone on here run landscape trucks or box trucks?
I don't see the convenience in them, other than the fact they can hold lots of gas in the side tanks. It just seems harder to access your equipment. :anyone:
I think a lot of what you use or run for a trailer or landscape truck depends on the situation your in. If your a larger company and have multiple crews with tons of clients the landscape trucks may be the way to go. If your a solo operator living in Florida where temps can reach 100 degrees an enclosed trailer can be out of the question for some. The simplest trailer to use is an open trailer, it's the easiest to set up and access while working. It all comes down to your situation.
...By pulling a trailer we can still utilize the pick up bed as well to haul stuff like limbs and other debris that we haul off from jobs.
We use open trailers everything you need is right there easy to get to.
I don't see any good reason to use a enclosed trailer. You use your tools out side. They are called outside power equipment. It's like driving your car in the snow then parking in a garage to keep it out of the weather.
