John deer is way better than any POS Kubota or craftsman I know somebody who had a Kubota mower stayed in the shop all the time then one day it decided to catch on fire and craftsmanship have horrible steering that strips out john deer rules
Are for real?
Junk Deere is the bottom of the line mower.
The decks are junk and the pulley setup makes the engine bog down to much in thick grass. The spindles break to easy and are over priced.
The only people that buy junk Deere mowers are those that wish that where farmers. It's like the fuktards that spend $100 on a pair of work pants just to say the did.
You can spend the same money on a craftsman or a cub cadet and get a lot more and better built mower.
I understand you like the pretty green paint but until you use other mowers for 500 hours how can you even think to say what brand is better.
A few years ago it was john Deere mowers going up in flames.
Out of over 100 mowers that I have craftsman has the best steering to fix.
You really should not have to much trouble with steering if you don't turn the wheels when not moving.
