Now let’s take things from the top.
Was it running before you pulled it down and why did you pull it down?
Pull it down, meaning rebuild it? If so, I hit a sidewalk and thought I broke my flywheel key. I didn’t, come to find out it was a broken rod, so I replaced the rod and piston. After further investigation, the sump was leaking oil, so I replaced that. It was working fine prior to this, although I think the compression was bad.
While it was apart what exactly did you do?
I replaced the following:
Flywheel key
Piston
Rod
Sump
Oil flingy thing in sump
All gaskets (Carb Included)
Replaced springs on carb screws
Replaced diaphragm and all pieces on fuel pump.
Replaced air filter and all pieces involved with that.
Replaced flywheel gear
Cleaned everything else.
What are your valve clearances?
I thought that didn’t apply to this motor. So, I don’t know that one.
You would have needed to adjust them to compensate for the depth of the valve work you did.
I took the valve “grinder gunk” and made sure they sat flush with the “block”
Did you check them springs on or springs off?
Springs where off while I was doing the work here.
Did you touch the cam?
Quite a few times :smile: . It was spinning and everything just fine, didn’t seem to have any problems there.
Have you tried to start it with the coils disconnected from each other?
I am lost on coils, maybe I am just having a brain fart right now, I will go google this and find out haha.
What exactly did you do to the carby?
I just took it apart and cleaned it, replaced gaskets and what not. Didn’t touch much of the innards except for the float, I replaced that.
The throttle linkage should come back and touch the idle stop screw if not something is not back together correct.
This is where I assumed my problem was, however I never touched the throttle linkage except to take the “wire” off.
If you insist on doing videos please get some bloody light in there, hard to work out what is going on when all I can see is a shakey black blob.
This was unnecessary, but… there are far worse videos out there. I tried to get up close so you could actually see what it was doing when it was started.
Is the flywheel key intact?
It was, but I already purchased a replacement so I installed that.
what is the compression? it looked like the engine was spinning way too quick of a motor with good compression.
How do I check this, I believe I had some problems here originally anyway?
If the valves are opening & closing at the right time and the spark is happening at the right time the engine will fire up on starting fluid, even with no carb there at all.
They are opening and closing, you can spin the cam and the pistons and valves open and close… timing on the other hand, I guess I am not 100% sure if they are correct.
So that tells me valve timing / spark timing is off or not enough compression or any combination of these three.
I guess what I dont understand from all of this is, if the timing is off, why would it start and run "fine". I can get it to start, then if I try to throttle up, it seems like it is going to blow up. If I idle down to much, it dies.
