2 Older Toro mowers with totally different spark plugs????
crazy charlie
  • / 2 Older Toro mowers with totally different spark plugs????
I own 2 old Toro mowers.A recycler GTS2 and a GTS5 OHV ,Mowers look almost identical except that the Recycler with the GTS2 motor reads "Toro" on it. Both have same brand plug with twin electrodes, one is a 12 and the other is a 22 with significantly longer reach head on it.Totally different plugs....totally different.The Recycler gts2 Toro motor has the 12 plug and is never easy to start and often runs for 5 minutes and then cuts off and restarts easily in 5 mins. The GTS5 with the 22 plug starts pretty easily and keeps running as long as I need it to.ID tags are long gone with age .Confused with plug differences and assuming the recycler may've incorrect plug...???? Anyone???? Thanks Charlie
Post the model and serial numbers for both units. With those numbers I can tell you what plug was used in both engines. Toro never used a split terminal spark plug in any of their units so I suspect someone has changed spark plugs in both.
crazy charlie
Thanks Rivets, I appreciate the offer to help. Unfortunately you missed one of the last lines in my post.These
are old machines and the tags are long gone.They deserve another look though.I will hose them down and have a closer look.Thanks again.Charlie
Have you looked under the sheet metal panel which holds the controls?
At least post a picture of the mowers. Maybe someone here can narrow it via visual ID.
I agree, never seen any split electrodes in a mower engine. Must be those E3 racing plugs with an extra 75HP each.
crazy charlie
Will check there for sure.Yes on the E3 plug .Thats the brand of plug that is in there and I have seen that in another of my machines......Dont recall which machine but I have surely seen that plug before.Charlie
crazy charlie
ok got some pics of both except the recycler tag.The pic came out bad and was under the control cover.These pics are
the one with the long reach dual head plug
crazy charlie
This is the recycler with what looks to be a common plug ,this mower is not easy to start, not easy to pull and Im not a skinny whip..lol
Here is the owners manual for the unit model 26622, which lists the plug to use in that engine. https://www.toro.com/getpub/7920
The other unit has a Briggs engine and will use a Champion J19LM. Can’t get you a manual because you didn’t post the model number. Post back when you get the number or have more questions.
crazy charlie
Will do thanks much!! Charlie
