PTmowerMech
- Apr 16, 2018
- 431
- 3,301
My brothers 915178 gravely ZT 42, I've had heck with this deck spindles all day. The Spindle nuts were put on by king kong. Finally got two off, with a 4ft cheater pipe, after screwing up two of the spindle pulleys, because I just couldn't find anything to safely hold the pulleys. Plus the 1/2 impact just wasn't cutting it.
One was on sooo tight, that I actually broke the spindle bolt itself.
Now, there's another round nut that looks like it needs a special two point tool that also needs to be taken out. I didn't have the tool, so me and my brother used a punch and back it out far enough to get a pipe wrench on it. But even that was almost impossible.
Luckily, I have the right size bearings in stock. So I don't have to replace those.
But I will have to replace 2 pulleys, and a spindle bolt.
Actually (brain fart) the pulleys are welded to the bolts.
Ok, first question. Is there an impact tool cheap enough online that'll fit the inside spindle nuts. And since the nuts where haaaaaard to get off, even after they'd back away from the blade, I'm assuming those other nuts will be just as hard.
I'm not finding any place to just by the spindle bolt. (with the pulley welded to it.) And the spindle assemblies are expensive. Are assemblies the only thing available?
Note to add. Since the 4 mounting bolts aren't going into aluminum cast, then is it safe to remove them, without worrying about them breaking off?
