captsteve.delta
Just bought a used Bad Boy Z60 with just 30 hours. I notice when I mow, if both drive arms are full forward, mower tends to turn to the right. Should it be adjusted so it goes straight with both full forward, or is that wishful thinking? Might this be an indication of problem with the wheel drive systems?
Just had a few minutes to play with it when I got it, so haven't even checked tire pressure, but visually it looks level. Any ideas?
Thanks
Thanks
