I am looking to replace my Husqvarna Garden Tractor with a zero turn, I have hilly conditions but have had a loaner the past week and can get most of the 3 acres.
Looking at
Husqvarna(M-ZT52), Simplicity(Champion XT), Bad Boy(Maverick) or Dixie Chopper(Magnum HP)... I like the idea of a Kawasaki engine but could be convinced out of it, just know that most the commercial guys around here use Kawasaki...
My real question is with the hills what should be my minimum configuration with regards to transmission? The tractors I am looking at range from Hydro Gear 3100, 3200 or 3400... Is it worth it to bump up to 5400?
Also is it important that the spindles be greasable cast iron?
Are any of the above mentioned tractors better on hills than others? or do you have another ZT in this range I should be looking at?
Thanks for the help......
Looking at
