ZD 326 Electrical
camden
I'm not getting any power down to the starter, Key switch is new but still no power. I bypassed the safety switches but still no power. Battery is good. I have power from main wire from battery to starter but not from main key switch, any suggestions??
Did you ?
The left stick
The right stick
The seat switch
The brake switch and the
PTO switch.
Or did you just pull the seat switch ?
The cranking circuit goes starting switch > pto switch > parking brake switch > solenoid > starter
This is a daisy chain with 12 V passing through all of them.
Then if there is a starting relay, the above goes to the + side of the relay trigger.
the - side of the relay ( or the solenoid if it s a 4 pole one ) goes ground >seat switch > left or right stick > other stick > relay or solenoid.
If you have a starter motor with solenoid attached then there is usually a relay fitted
camden
thanks for suggestions, yep I bypassed them all, I have a electrical schematic and followed for the safety switches. I'm thinking of ringing out the wires.
Well you are one better than me I don't have a schematic as Kubota are a bit secret squirrel with service information.
So by bypassing are you jumping the through connections ?
And is there more than 1 fuse.
Which engine do you have fitted and what type of starter motor solenoid ( attached or remote ).
