I called my local John Deere dealership and spent an extended time on hold in the parts and service departments without getting a clear answer. I thought there may be someone on this forum who may have made the switch from EFI to a carburetor. I have a good 26 HP motor that I would like to put on the mower, but I also believe the EFI mowers have a crank sensor and other wiring that a motor with a carburetor will not have. Thank you,
