My mower stopped running today. When I turn it over there is a very loud double clunk with each rotation of the crank. So, I don't think I'll be taking the time to investigate. It has 800 hours and when I took the shroud off there was a lot of fur packed around the cylinders
. So, I am sure it's toast. Anyways it is a 24hp 44L777-0144-G1 and I can't find a replacement for less than $1200. I found a new 20HP 40N877-0059-G1 that should drop in for $600 new.
What do you think?
What do you think?
