Greeting all,
First time posting as I am currently at a loss or am in denial.
I have a Husqvarna YTH2448 with a brand new transmission maybe 20 hours operation time. I also replaced the drive belt 2 days ago.
My problem is the mower will only move in reverse (Pulls very strong). I am able to temporarily have the mower move forward by playing with the shifter but then quickly slams into reverse very violently.
I have checked all the belts and tensioners and them seem tight.
I have manually turned the transmission without the belt attached and the am able to make the mower move forward.
I have looked at the linkage and everything seems to be intact and functioning correctly.
Is my transmission broken again? What else could be causing this reverse problem?
