YTH 24V54 Trans axle mounting brackets
Backroads
2020 YTH24V54 has any one have problems with broken or split trans axle mounting brackets. All 4 brackets are broken or split.
If you are seeing cracks at the axle mounting flanges on the frame that normally means that the front transaxle support has either broken, broken the bolts off in the front of the tranny, or they have just fell out.
