Yardman "Turtle" on Craigs list
silver1
My local list have a yardman riding mower with a 8.5 B&S engine for 100 bucks.
I'm waiting for the model number. I has had 400 in repairs, but needs a Shift cable.
I could use some pictures of the Green and Yellow "turtle" to find a model.
Any help is good.
LB
Carscw
I think what your talking about is the MTD yard bug. Looks like a turtle The shift cable just changes from forward to backwards. It has the same set up as a shift on the go but has a pedal not a lever. You can push mow a yard faster than this thing goes. I have one I let my kids ride around on.
Sent from my iPhone using LMF
silver1
Thank you for the input.
A Yard bug.
midnite rider
Any help is good.
LB
It is called a Yard Man Yard Bug.
Here is a link to the Operators manual.
I have attached some pictures of which one shows the model #. Hope this helps.
midnite rider
This Yard Bug has the 9HP Briggs & Stratton engine though.
Never understood how they measured a half a horse. :laughing: :laughing:
silver1
Thanks for the input.
Maybe the 8.5 Hp is low-emissions Calif. model!:thumbdown:
Carscw
Mine is a 8 .5
corvairbob
they came with 8 and 9.5 hp engines the shifter cables are hard to find but you can get them on ebay for 39.00 paste this into ebay search. MTD 746-0935A, 946-0935A CABLE TRANS. SHIFT.OEM i just got 2 of them for 69.00 they are a bicth to install unless you do some dismantling. i placed my eyes on the end of my fingers and managed to get the top cable on the trans shifting lever under the frame. not bad to hook up at the top. but watch it when you test it. they are easy to get backwards. so start it run slow shift into reverse and push the go peddle and see if you get it correct if not just switch them
the yard man model is 13a=328-402 and for the guy that said they are slow must have 6 ft legs because i can mow my yard in 1/4 the time it takes to push the walk behind that is self powered.
if you need any more numbers just ask. i like mine but i hate the way it cuts. leaves the grass down from the front tires and then that grass grows and it looks like the deck did not do a thing. i'm trying to figure out how to get a high lift blade for it to make the cut even. the 3 in 1 blade just won't do it. i don't bag just side discharge and mulch. thanks good luck
