XT2 SLX50 will not start
camel24hrs
I purchased a XT2 SLX50 last December. It has ran fine till now. Tried to crank it and all it does is rollover. I took the air filter off and squirted some either in it and it did not even try to fire. Dealer is 80 miles away and I have to borrow a trailer to take it in. Is there anything I can try before I do that? This has the EFI engine. I assume it has a computer on it but looking at the parts diagram I cannot even find it listed. Unless its all in the push start module. Anyone know where it would be located?
Scrubcadet10
Moderator
Staff member
Remove the spark plug and shoot some gasoline or starting fluid through the plug hole, reinstall plug and wire, try to start, if it fires and dies you have spark, and a fuel issue... if it doesnt fire, then no spark, and possibly a bad ignition coil or something grounding the coil killing spark.
mechanic mark
