xmark kawasaki engine
byount
while I was rebuilding the engine I found that the valve guides are moved out of place is there a fix for this or do I buy new heads. ( was smoking )
motoman
If the guides have moved the heads were probably overheated ruining the alloy hardness. Briggs (for instance) will not sell bare guides, probably because they will also move when reinstalled. When I had the problem the press fit measurements were ok , but the guide moved again. New head with guides solved the problem. In my case only one of the Intek V 24 heads was affected suggesting a casting quality problem also.
