Would you buy a multi-attachment piece of equipment?
Would you buy the Echo PAS or Stihl KombiSystem being a LCB owner?
  • Total voters
    22
Available in the spring of 2013 is the Honda Versatool......similar to the Echo Pro Attachment Series or the Stihl KombiSystem. I don't know if it will be available in the U.S., though.
Honda Versatool.jpg (See it here: http://www.lawnmowerforum.com/honda-forum/13533-honda-products.html AND here: http://www.hondagarden.com/product.php/1401/honda_umc425)
I noticed the blower attachment looks different than the one from Echo/Stihl. (See pictures). Does one design increase air velocity or something? Or is it pretty much the same thing, it just looks different?
Hondahonda versatool blower.jpg Echoecho PAS blower.jpg Stihlstihl kombi blower.jpg
aron33mc
They are great for the homeowner, however, commercial settings seem to beat up all the pieces. Mostly where they attach together. Mostly, time is money and the right tool is the one made for the job being done which equals less time messing around. Have a great day!
exotion
I run a dedicated weed eater (echo) because it sees the most use and i need to be able to trust it. I am planning on buying the echo PAS with edger attachment so i have the PAS system to use and i need a shaft edger. I do not want 10 pieces of equipment for my pole hedger, garden tiller, pole chain saw, brush cutter, edger, bed redefiner, etc etc If I had a seperate piece of equipment for each of these my garage would fill up very fast. not to mention saving room on my trailer for field work.
