Worth Garden Lawn Mowers
tblank
Has anyone heard of them before??
Worth Garden 21" Aluminum Deck Self Propelled Gas Lawn Mower
http://www.sears.com/worth-garden-2...erId=SEARS&prdNo=10&blockNo=10&blockType=G10#
https://www.amazon.com/Worth-1879-Aluminum-Propelled-Powered/dp/B01HAH32DM
Worth Garden 19" Aluminum Deck Self Propelled Gas Lawn Mower
http://www.sears.com/worth-garden-1...erId=SEARS&prdNo=11&blockNo=11&blockType=G11#
https://www.amazon.com/Worth-1953-Aluminum-Propelled-Powered/dp/B01HAJ36Q8
Was about to pull the trigger on this Craftsman AWD (made by Husqvarna)
http://www.sears.com/craftsman-7.25-engine-torque-just-check-add-all/p-07137489000P
If you had to buy a push lawn mower from sears for less than $450 which would you buy?
And any one who tells you the mower has a "Compressed alloy deck" would be a little suspect.
1) they did not read their own advertisement
2) they have no idea of physics or engineering
3) they just translated the Chinese with Google translate and have no idea a all about what they are selling
4) High carbon steel is the wrong material for mower blades as it has poor abraision resistance and if not properly heat treated can shatter.
Remember those cheap taps that snap off the instant you start to cut a full thread , same material, hard, sharp & brittle
But then so is this: "Featuring Check and Add™, the first gas-powered engine to never need an oil change, just simply check and add oil for the life of the engine"
