Model 33R777
Type 0003 G1
Code 190214ZD
Single cylinder.
Will not spin past compression stroke.
Battery measures 12.8 v. Starter is new (and all this was tried with 2 used starters as well, so 3 different starters).
Battery connections cleaned, starter relay connections cleaned.
Battery voltage measures 12.7 all the way to the starter; battery, starter relay input, starter relay output, starter lug.
Remover spark plug, spins like crazy.
Attached car battery. Will not spin past compression stroke. Remove spark plug. Spins like crazy.
Attach compression gauge, struggles with partial spins, but got 100 psi , so it may register more if the engine could spin enough to give a good test.
So, why, if all parameters measure good, will the starter not get past compression?
Thank you,'
J
Type 0003 G1
Code 190214ZD
Single cylinder.
Thank you,'
J
