Repairs wont shut off
bbur
I have a toro wheel horse 244-5. It has a new ignition switch. It turns on with the key but will not shut off with the key. Any ideas? Oh yeah somebody tried to jump the celenoid recently.
reynoldston
You have a bad ground wire some place. Did you install a OEM switch because Toro has its own switch.
bbur
yes it was an oem replacement part. I think you may be right because the other day it was shutting of fine with the key but yesterday the same thing.
mechanic mark
bbur
Hey man thanks alot. I appreciate your help.
