Hello everyone,  I just purchased a piece of property and it came with a Murray Model 80-4169 Lawn Tractor.  After tinkering with it for a little while I was able to get it started and it actually runs very good.  It will drive (very slow) in 1st gear and reverse but will not go in 2nd, 3rd or 4th gear.  I have mechanical skills but really don't have time to take apart the transmission or rear end to inspect and I'm not an expert on lawn tractors.   I did drain and replace the rear end fluid.  The old tractor is in pretty good condition and it has a big pine straw rake attached to it so I would really love to get it going.  The previous owner used to hook it up to a Kawasaki Mule and pull it around the property to rake up the pine straw.
Any help or thoughts on what to check would be greatly appreciated.
thanks,
Wayne
thanks,
Wayne
