Hello everyone. I made have made a big mistake buying a used IS4000Z with a Kawasaki FD750D engine with a 61" deck off of eBay.
I knew it needed work done but didn't know that the wiring harness had been reconstructed. Someone put a second selonoid on it, when the starter comes with its own selonoid. It want start with the key being turned but it will turn over when you touch the contacts on the starter.
It will run briefly when I spray some starter fluid in carburetor. I'm thinking it may need a complete new wiring harness do the fact that the oil, temperature Gauges don't work either.
Does anyone know where to buy a complete harness for this mower?
I wonder if it's worth it?
