Ric
- May 7, 2010
- 5,765
......I appreciate all the replies, and I understand like with most topics not everyone is going to agree on every point :smile:
Since I do not have loads of money to replace my mower frequently I need to err on the side of caution to try to get the most years possible out of my new mower :smile:
Now I know I can't take that to the extreme, for example - only mow when the grass is dry as toast :smile: .....or else my yard might get occasional long periods without being mowed at all, dry grass is preferable and soaking wet grass might not cut as well as dryer grass, but there will likely be times when the grass is not quite as dry as I would prefer, but I would likely avoid mowing really wet grass.
I guess the bottom line is what works best for my particular model (YTA22V46) as not all mowers are built the same.
Fortunately I only have to mow my own yard, so I don't have to feel pressured to mow soaking wet grass like someone with a lot of regular customers waiting for their yard to get mowed :smile:
For your particular model (YTA22V46) I'd mow when the grass is at it driest and often so your not cutting anything to extremely long. Late Evening is preferred. Keep your grass clippings as short as possible. Short grass clippings decompose faster and will drop to the soil to help in the fertilization needs of the soil instead of lying on top of the lawn and baking. Rule of thumb is not to remove more than 1/3rd of the total height of the grass. Take a look on the net and find out what cutting height is recommended for your type of grass.
