I've got an old Toro push mower with a Briggs #127802-0640-01. The primer bulb does nothing and I have to pull 20-30 times to get it to start - or remove the air cleaner and use starting fluid. It runs great otherwise.
I replaced the bulb last year and it didn't help. I'm assuming it's a gasket. Can anyone tell me what's the most likely gasket that's not letting the bulb prime?
Thanks.
Thanks.
