SidecarFlip
- Aug 21, 2018
- 282
Farmall did that on tractors years ago. I ran one for a guy back many years ago that was that way. We used it to feed cows in the winter time when it was real cold. You would go into the shed and start it on gas and then go sit in the truck where the heater was and let it run till it warmed up. Then you went back and switched it to diesel. It would smoke incredibly. When it finally started running on diesel you could then go back and sit in the pickup a few more minutes and wait . After it started and warmed on diesel for a few minutes though then it would run good. It was strong and reliable.
No not diesel, distillate (kerosene). I had a 50's Farmall dual fuel myself, they won't run on diesel and even on kerosene you'll get a face full if the wind is blowing the right way. They were bullt to adopt to the gasoline shortage during the war.
