Engine When did JD change to the Kawasaki 24hp engine for the Z655?
a480381
  • / When did JD change to the Kawasaki 24hp engine for the Z655?
I just bought a supposedly new JD Z655 and it came with a 27 hp engine. It appears to have a lower cc rating than the Kawasaki 24 hp engine that I thought I was getting. Did I buy 2015 model which I thought I was paying for or did I get an older model? The salesman found it at another dealership so that I could get it earlier than ordering from the factory. I am a little disappointed because I did not end up with the Kawasaki. Should I be?
motoman
a48, Tell us what engine you got.
Jack17
JD relabels most of the engines they put on their machines with JD name now days. If the engine you got is the FS730V its a Kawasaki.
Ric
Can you take a picture of the engine, I'd like to see it. The spec's I find online says it's a B&S
https://www.muttonpower.com/p-9042-john-deere-eztrak-z655.aspx#SPEC
Ric
If it's a27 hp Kawasaki engine on that machine it wont be the FS or FR engine because it's a residential machine and Kawasaki according to there site doesn't make a 27hp in either the FR or FS. It would have to be the FX 850V to be 27 hp. The Spec's I found says its a B&S
Ric
Jack17
Ric
I seriously doubt it's going to be the 850 because I can't see them putting that engine on a residential mower. That's why I said I thought it's a B&S if it's in fact a 27hp. I'm just guessing but its more likely the Professional grade 27 B&S. If it's a Kawasaki it will say Kawasaki, it wont be re-labeled. The one below left is what they show on the mower.
Jack17
Looks like OP ain't coming back! We will never know:confused3:
