Export thread
When did dixie chopper go from 2 bearing setup to 4 on front wheels on SE r did they?
#1
R
RCountry2
Hello me again! On my 2012 had a front wheel bearing on left side fail apart. Looked up the part numbers for a 2012 SE 27/60 which calls for 900340 Bearing Kit which has 4 bearings...2 flanged outer and two inner and a spacer. The ones I removed from wheel was just 2 outer flanged bearings and a spacer that fills in the void between the 2 sets of bearings (per the parts diagram it shows only two outer bearings with a spacer). So I'm guessing they redesigned it with two extra bearings? Thing is the spacer that came with the kit was too long so I had to cut it down to a length of about 62mm. I'm guessing my wheels are not the original that's why the spacer was too long and Dixie Chooper did redesign it using 4 bearings (or guess drawing on parts diagram could be wrong?)
