Rdfaber1956
- Jun 28, 2025
- 1
- 3
Thanks!That is a familiar problem to me. Someone ran into a solid stop on the left front wheel and the steering rod is now bent. (Left side as seated on the machine)
Thanks!Things to looks at would be the steering sector gear, and bushings. The wheel spindles, the tie rods, The front axle and bushings, and in some cases even the frame were the axle bolts into it.
