wheel sticks
briggs206
what causes the wheels to stick when backing the mower up? I cleaned and greased the gears but im wondering if this is a trans problem?
JohnBoy1
How much slack do you have in the self propelled adjuster, if it's to tight it will lock the wheels up backing up.
briggs206
il check that out. maybe its too tight. how should it be when set correctly?
beg
had one that did that last week I took the gear off and lubed the spring in the groove on the axle under the keyway.
briggs206
I found my belt slowly spins the trans pulley keeping the rear wheels locked even when my handle is fully released. im using a 33inch belt which is what it calls for. do I need a lawn boy brand belt?
