Export thread
What spray lube do y'all use?
#1
C
cjdave
For general lube ,rusty threads or to free up pullyes, just general use. WD40,PB blaster,White lithium grease, or do y'all recommend soomthing else? Thanks for the help David
#2
H
hitmanharleyk
The best made is what I use and I'd put it up against any made. Open and Shut by Lawson Products.
#3
reynoldston
reynoldston
They all have there place, you need more then one can? general oil lube- anything that needs oil, penetrating oil- rusty bolts or freeing up what ever like pulleys, white lithium- anything that needs a light duty grease, WD40- ? don't know what its good for but I always have a can of it. silicone lube- anything rubber like brake parts or plug wires, Brand names- anything on sale.
#4
Sammy the Red
Sammy the Red
Fluid Film for a lasting oil lube.
Liquid Wrench lube for a quick oil lube.
WD-40 to wash nuts and bolts dropped on the ground to clean them.
#5
BKBrown
BKBrown
What is a y'all ? :wink: Is that some kind of boat ?
Militec - bonds to metal when it gets hot then dries without being sticky.
Prolong -- PB Blaster -- WD 40 if it needs moisture removed and then real oil.
Moved to VA in 74 and still can't bring myself to use "y'all" -- here it is y'all for 1 or 2 and
"all y'all" for a group.
Where I grew up it was "you", or "both of you", or "the two of you", or "all of you".
"How y'all doin?" "We all is fine."
Not attempting to offend anyone - just pointing out differences in language from different areas. :smile:
