Blades What size blade do I need
Gta_g20
So I picked up a couple mowers and this one has no blade or blade bolt securing it to the crank. It is a craftsman gold with 190cc and a precision cut. It has a serial number on the engine itself but nothing I can find on the deck to tell me which model I have. I.pt needs a blade and I’m unsure if it’s a 21 or 22”
Any advice is appreciated on where to look for a model number stamp
SeniorCitizen
I don't recall ever seeing a Mod. No. on a deck.
If you have a meter stick, invert the mower and measure the radius from the center of the crank to the deck X 2 and subtract about 12 mm. With that and the shaft size maybe we can work it out.
Gta_g20
Got it 22”
