WHAT MOWER IS THIS????
LAFORD1986
When I was a kid, in the 80's, my Dad had a BROWN push mower with a WHITE engine. It did not have a pull starter. It had a handle on top that you would "unfold" wind up, fold back in and push a button and the engine would start. Does ANYONE have any idea what kind of mower this is????
Carscw
The engine is a Briggs.
Is one wheel offset? Sit behind the shoot
(( racing is the only sport that you need two balls ))
LAFORD1986
Cant remember. I know he did have one like that with the offset front wheel but it was a different one. the offset had kinda of a square deck..
JSB33
My Dad had one like in the video. This would have been the mid to late 60's.
My memory tells me that one wheel was offset, and that it also used the button for starting. It was also blue with a white engine.
cashman
Tecumseh had a wind up starter also. There were a lot of Sears and Roebuck mowers with that set up. If I remember right, a lot of those mowers were brown color also. After you wound up the Tecumseh, there was a button that you pushed to start the engine. Under the right conditions, those wind ups were pretty dangerous and we were warned to never put your fingers under one unless you knew for sure that the starter wasn't wound up. Thanks!!!
Mini Motors
White was never a stock color for Briggs, but was for a Tecumseh. That's not to say there was never a white Briggs engine, but a deal had to be a large one(ie;Sears) to make a production run of a white motor. And they might shy away from white because of Tecumseh. I really liked the copper colored Briggs.
1 Lucky Texan
My Dad had one, i THINK it was a Sears or possibly Montgomery Ward, less likely Western Auto. Except I kinda recall a brown or gold color - not sure.
I'm leaning towards a Wards but, it wasn't that much more convenient than a rope start, and the spring starter eventually broke. pretty sure it was a briggs engine though. I will NEVER forget that clicking sound of the spring starter! thanx for linking the video!
I also have vague memories of a gadget my dad got to chuck into the drill that had some 'nubs' designed to push into the perforated vent/screen on top of a mower to use the drill to start. Anyone recall that? maybe advertised in TV guide -- possibly on TV as well?
Brucebotti
That video sure was a trip down memory lane!
I also remember my Dad having a similar type mower. From what I remember though, is that you turned the crank, and it would turn the mower over as soon as you folded it over.
Bruce
