What engine is this?
Mayday916
Hey gang, I got this Snapper for next to nothing. Just for fun, and this being my 1st restore I'd like to fix it up but I'm not sure who made the engine? any info/tips is appreciated! IMG_20170511_184441.jpg IMG_20170511_184451.jpg
It is a Tecumseh engine. When you take off the plastic shroud you should find a model number on the metal shroud.
Mow Joe
The engine #s should be visible without removing anything. They will normally be just above the spark plug, stamped into the metal of the blower housing (the part the recoil starter bolts to). The problem I see with this engine is that the blower housing is painted the wrong color (should be white). This makes me think it could be from a different engine or possibly a new replacement. If it is the latter it won't have any #s. If it came from another engine it will be a tossup when trying to get parts for it.
Mayday916
Thanks for the input all! I had a friend confirm that it is a Tecumseh. I took the plastic shroud off and didn't find any numbers. So, it does look like it may have been replaced once upon a time like Mow Joe said.
rgpsctl
Hey gang, I got this Snapper for next to nothing. Just for fun, and this being my 1st restore I'd like to fix it up but I'm not sure who made the engine? any info/tips is appreciated! <img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=32171"/> <img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=32172"/>
Hope the model number tag is still on the mower deck. Use the model number to look up a parts manual. Snapper usually list engine model and type used.
