What’s the correct carburetor number for a Stihl FS 38 trimmer
Dufferman
  • / What’s the correct carburetor number for a Stihl FS 38 trimmer
Hi from Canada,
I was gifted a trimmer from a neighbour FS38 and the primer bulb wouldn’t fill.
I took out the carb and everything was gunked up so I want to get a new carb, filter and plug. The carb I removed is a C1Q-S95 but I think it is not the original as I called Stihl and tried to provide a serial number that was partially missing .
The representative said I should try C1Q S186.
My question is. Where can I find the engine mode number so I can properly match the correct carburetor to the trimmer?
Is there a location on the trimmer / engine where the number is located?
There is no stamped 9 - digit number on the belly of my unit
Fish
Looking up the serial #:
Product Type : Trimmers
Model : FS38
Serial Number : 261784642
New Product Registration
Dealer must not haved filed the registration......
Fish
If your trouble is that the throttle cable end doesn't fit in the new carb, they did a change a few years back, they switched to a cable with a "z" bend.
jp1961
Hello,
It looks like it has a Zama. Here is a YouTube video of how to clean/rebuild it.
I would try just using carb cleaner first before trying to rebuild it. Just shoot Gumout into the gas lines.
https://youtu.be/7VM6ZAT96o0
Regards
Jeff
I suspect that is the original carb. Found a chart that showed the FS38 with both the C1Q-S95or the S97 carbs. I am sure that number has superceded to a new carb. I have always provided the model number of the trimmer and the number off of the carb and we go from there. I have seen my local dealer pull out of separate book that list the carb number changes,
Dufferman
Model : FS38
Thanks, that is helpful.
I think I will go with the C1Q- S97 carburetor. The diaphragm, primer bulb and fuel filter need be replaced so I will get the entire kit and install
Fish
Does your throttle cable have a z-bend like this one?
Other than this issue, any carb will work fine. The different throttle cables are the only issue that may give you trouble.
Dufferman
F56109F1-F945-4594-9A3A-8ACF3A99B085.jpg250071B2-49FF-4026-BF73-F5B3D2A2000C.jpg8E83ABE3-4F4D-411D-B046-68CAAF43ADF2.jpgF56109F1-F945-4594-9A3A-8ACF3A99B085.jpg250071B2-49FF-4026-BF73-F5B3D2A2000C.jpg8E83ABE3-4F4D-411D-B046-68CAAF43ADF2.jpg
Dufferman
Here’s a picture of the carburetor that was taken outDD8A26B2-3A5B-46B1-98F6-91130840A38D.jpg
Fish
Here is what is on the fs38 these days, you need the model with the swivel piece.
