l008com
- May 25, 2015
- 43
- 246
I bought this old leaf blower for $35 on craigslist because I wanted something cheap that could vacuum and chop up leaves. It ran well at the time, except one of the exhaust bolts was stripped. Well it turns out it was the engine block that was stripped, not the bolt. But I was eventually able to get the hole re-tapped and use bigger bolts to get it on there. So I finally had the thing running well. Then, as soon as I got it running well, suddenly it wouldn't start at all.
So I pulled the cord till my arm fell off, but it would not run. It was running perfectly, then suddenly not at all, so it doesn't sound like it would be a dirty carb (but who knows). To me it sounded like a fuel line issue. When I took the cover off and pumped the primer, it didn't pull up much gas. So I figured its either the bulb or the lines, might as well do both. I did them today and it sure looked like the lines. The in-tank filter had fallen off and the lines in the tank looked like they had crumbled a bit. So after fighting with this thing for a couple of hours, I was able to replace both fuel lines and the primer bulb. But alas, no change in starting.
And lets back up a bit... I WAS able to get it started before off of starting fluid. But once it ran out, it would sputter and die. All the more reason it seemed like it was old rotted fuel lines not sucking up the gas.
Did I mention it was a 1998 model blower?
Well today, I couldn't get it to run at all. Not off gas and not off starter fluid. I actually thought I was going to be successful with this project, but nope.
So any thoughts on what might be going on with this thing?
Here is a picture of the carb before I took the lines off. Can you tell which is the fuel line and which is the return line? I thought the fatter one was fuel, and it sure looked like that was the one previously attached to the in-tank filter. But when I primed it, I could see air bubbles going down that line, into the tank. After a while, I finally gave up. I'd think even if I had them on backwards, it would still probably work, it would just be sucking in un-filtered gas? But just to be safe, I switched the lines. No difference with the lines switched. I am officially stumped.
