Warner PTO problem
Dave Olley
Hi, my mower has a Warner 5217-45/-89 PTO clutch/brake
Recently I removed the PTO to change the mower drive belt/ Somehow, while it was removed, the rotor went missing and can no longer be located. I have been trying to source a replacement, but with no luck. Everyone wants to sell me a complete unit, but I just need a rotor plate. I have contacted Warner, but no reply.
So, a couple of questions, if I may.
Does anyone know of anyone who might be able and willing to supply such a part, new or used.
Does anyone know if the part from a different, but similar Warner clutch might fit and work, or does it have to be precisely the original unit.
Has anyone got one that they think will work that they would be willing to sell and post to me.
Many thanks
Dave
Usually by the time I change PTO clutches both the rotor and armature are heavily worn. Besides how in the heck you did lose just a large piece as the rotor? When removed I zip tie the assembly together to keep things to together. And rotors here very ever come out as they are usually stuck in the bearing.
