Vtwin intek almost stalls under load
choi0706
I have a issue with my mower, well two issues to be exact.
It starts fine, however the idle rpm is pretty high, I checked the spring and it's correctly on the bracket. The other issue I have is the engine will die if I try to mow the grass. The rpms drop a lot when I try to mow, it jumps back up once you disengage the blades.
First do a cylinder balance test as it sounds like one cylinder is not working.
choi0706
I will try it out this weekend, however what else do I check if both sides are getting spark?
Fish
You check it for more than that. Just unplug the plug wire on one side, and try to start.
Then do so on the other side. If it starts on one side only, then you know what side your problem is on.
Sounds like a blown head gasket on one cylinder.
choi0706
Ok so I replaced fuel filter. Oil. Fresh fuel. Sparkplugs
Both sides got spark, but pulling the right side kills the engine. And pulling the left does nothing. Something wrong with left side. After pulling both plugs out, and cranking the motor it feels like both sides have equal compression. I did not have a gauge with me.
choi0706
Opened up the valve cover to find a loose intake pushrod and fallen retaining nut.
choi0706
When I turn the flywheel the pushrod does not want to go back in.
choi0706
I managed to re install the push rod and reset the lash.
But now the engine over revs. I believe something is wrong with the governor arm.
