Voltage regulator wires? Please help!!
craig1980
Hi All, This is my first post and hope I can get some help. I own a exmark lazer z 25 hp Kawasaki Fh721d. Anyway, the wires going to the voltage regulator got disconnected and Im not sure how they go back. There is a double connector (white) and a single blue connector. What order do they get connected back? There is only two different combinations, but Im really worried if I mix the wires up I will hurt something or short something out. Any help is greatly appreciated.
EngineMan
Have a look at this......
craig1980
Thank you for the diagram! Does it look pin 2 and 3 are joint together?? It looks like there is a small line connecting them. Am I wrong?
Fish
No, they are not connected, that is just the part of the drawing of the edge of the regulator, those two wires are ac voltage that
go into the regulator, and the rectified dc voltage comes out the other terminal...
craig1980
From the top of the first pin going down - Blue first (single connector) than White/white (double connector)
