13obrienjo
I know this is a little early but im already thinking about this falls leaf removal.
In the past it hasn't been a very big part of my business but this year im looking to make some more money in the fall. Normally I just blow all of the leafs into a pile and then use a pitchfork to throw them into a trailer. This isn't very effective.
Im considering buying a leaf vacumm, it looks like billy goat is the big company in this market. I have a 1 ton dump truck that im planning to use. I was thinking about putting the vacumm into a small trailer so i can unhook it when dumping and not having to worry about mounting and unmounting it. Also i could throw all of my rakes and blowers and gas into the trailer and not have to worry about having a second truck with me.
I have found quite a few for sale on Craigslist between 1000$-1500$ for 16 to 18 horse power. Is this a good size or is it like wood chippers were bigger is generally better and you need bigger to be very effiecent. I watched several videos on youtube and the ones on C.L. looked just like what the "pros" were using to clean up huge piles in like 10 minutes. I just don't want to be spending all of this money then have it take just as long as it did before.
Also how much are you guys charging roughly for leaf removal and how long should each yard take me from start to finish, I mostly work in under 1 acre lots in residential/suburban areas. I know it verys by location (I work outside of Lansing Michigan). Also there will be two of us and maybe a third if I end up with lots of work.
Any help would be appriciated, thanks
