This past spring I replaced my Lawnboy Platinum with a HRX217VKA. After three months of use I thought I would post a couple updates. To start my main problem with the LB was lack of power from the B&S 6.75 tq rated engine. The Honda has not let me down! Lots of power. Anyone with Bermuda grass can tell you it is a challenge to cut. The cut quality is as good as the LB....and that says a lot as I had no issues with the cut. The difference is the Honda does it without breaking a sweat....not so much for the LB though. The deck of the Honda does far better of not collecting clipping and needing to be cleaned. The Smart drive has worked great. The Honda has always started on one pull. All said I would buy the Honda again.
Looking forward to next season. The lawn should shape up even better next year as I have hired a lawn service mostly because of a loosing battle with crabgrass and nutsedge (neighbors). I had little luck with Halts as I probably should have done two applications this spring instead of the one. Also I plan on cutting lower next year. This year got kind of mixed up as my spring scalp was done with my old LB and following cuts with the new Honda. The cutting heights did not jive....in turn I am cutting higher than I would have liked. I am at 3" now when I should be at 2" or 2.5". This may sound confusing to those who do not have Bermuda grass.
