Unusual battery issue
donb108
I'm working on a Craftsman 42" riding mower (917.270622). I'm trying to replace the battery. It doesn't have the original battery, so I checked some youtubes. It looks like the battery is installed with the positive connected to ground; i.e. 12Vdc-positive ground. I've never seen one setup this way. Is this correct, or did someone goof something up?
MowerNick
I see customers install batteries wrong all the time. Some people don't know they make those batteries with the posts on either side. I've seen briggs intek motors actually turn the starter the opposite direction when hooked up backwards haha.
donb108
Not sure how, but I think I got it wrong. I removed the red cable connected to the (+) terminal, cleaned it up, an tested for continuity from it to the frame; nothing, no connection. Then did the same test on the black cable; dead short, as it should be. Tracing the cables, the red cable connects to a contactor and the black cable is bolted directly to the frame.
Last night, while doing quick tests, I just checked for continuity from the battery (+) to the frame and got a beep from the meter. Same check on the (-) battery terminal gave no beep. Maybe the battery is shorted and I got continuity from (+), through the battery, through the black cable, and then to frame. Then, when testing the black cable, didn't have good contact on the meter probe??
All very strange. Maybe all I need to do is install the correct battery. Does this one from Walmart look OK?
BTW-thanks for the help!
donb108
By the way, after removing the old battery, I put it on a charger to see what would happen. It pegged the meter on the charger; only left it on for a few seconds.
7394
Throw a voltmeter on it & see what that reads..
Cusser, I don't the problem.:ROFLMAO:
Nor do OEMs I have seen black cables on both positive and negative sides. Just did a JD 420 eariler that I use a section Red heat shrink to id the positive cable after the owner fried the wiring harness and alternator. But what do you expect for a 1958 model?
