Good afternoon. I have a 2023 Z412 with a Kubota mulching kit. I replaced the blades about a month ago with a new set from Kubota. I noticed that there appears to be about a 1/4" difference in cutting between the center blade and the left side blade. I thought I had either failed to seat the blade correctly when I installed it or I had a bent blade. I raised the mower and verified it was properly installed and when I spin them I can tell that one side is about a 1/4" lower than the other side of the blade when it comes around to the same spot. I then got one of the old blades and put it on and it is doing the same thing. I haven't kit anything and nothing appears to be bent. I'm also not sure how I didn't notice it before. Has anyone ever ran into this issue and what am I missing? Thanks in advance.
