P Paulz2821 Member Aug 4, 2012 #1 so all i need to do is cover up the side shoot and get mulching blades right? thanks
lawn mower fanatic Lawn Pro Aug 4, 2012 #2 Correct....Some mowers all you need to do is cover up the side shoot, you can keep the same blades....but in your case, I don't know about that.
P Paulz2821 Member Aug 4, 2012 #3 i got the gator blades to go on it now that the wet season is starting up. i'm having a plate custom made to go on the deck. 5x15 with 13" on the bolt spacing. :thumbsup:
