I have a Turf Tiger SST/61A serial # 545xxxx with 25 HP Kohler. Replaced the PTO clutch less than a year ago (it was completely worn out), PTO switch, and recently the ECM.  I was having a previous issue with the PTO switch not engaging.  I have checked all safety interlocks and they are fine.  With the engine running I can engage the PTO and the voltage on the light blue wire from the ECM goes from 12+ to 0.  I assume the light blue wire is what actually energizes the PTO clutch.  I can bypass the PTO switch with a toggle switch and the clutch engages immediately so I am confident it is not the clutch or wiring to it.  Is this likely a poor ground?  Any ideas?
