TSC/Huskee/MTD 5 hp rear tine tiller axle lube question
billmccoy
  • / TSC/Huskee/MTD 5 hp rear tine tiller axle lube question
I inherited a nice old TSC/Huskee/MTD 5 HP rear tine tiller ( I believe a mid 1980's vintage) without a manual. I am trying to find out the recommeded grease/gear oil for the transmission/gearbox. I have found a plastic fill plug on the top of the gearbox housing, but no dipstick or fill level plug on it. Any suggestions as to how to determine the level, and/or what product I should use? It is a model 213-430-131.
Thanks
Your have a 1993 rear tine tiller made for TSC. That tranny uses 40 ounces of 737-0300a benalene grease. it comes in 8 ounces tubes from MTD at about $17 per tube.
There is no way of knowing how much grease is in the tranny without total disassembly and refill from scratch.
billmccoy
Thanks for the quick reply. It is greatly appreciated.
