TS-348 Mower Deck lifetime warranty
Kenneth Brock
Purchased a TS 348 Lawn tractor new on 8-26-2019 with a lifetime mower deck warranty from Johnson's ACE Hardware,10409 E Greenville HWY, Wellford SC 29385,
Registered it that day with Husqvarna. Model 960430230 00, ser # 121917A001120.
The small protection moon shaped metal piece at mower deck ejection area broke loose in Nov 2020. The piece of metal wrapped up blades and severely damage mower deck. I was told by Husqvarna to take it to where I purchased it.
Ed at Husqvarna Warranty dept was contacted by Ace Hardware store and warranty repair was turned down.
I was stuck with a over $1,400 repair bill.
I dropped of the mower again 12 May 23 with exact same break in weld. I stopped before major damaged occurred. I can not believe that I am going to have to buy another deck within 4 years of purchase. I will pursue reimbursement...no luck last time. Beware of B.S. warranties.
IF you are referring to item 20 in the diagram it is replaceable. Usually the carriage bolt heads wears off and the part gets damaged.
And that lifetime warranty is more of selling tool as it only cover failures in workmanship and not normal wear.
