Troybuilt 320 not picking leaves
nj121
Guys,
I just came across this forum and looking forward to learning from you all.
I am a newbie here.....
I have a troybuilt 320 since last 4 years. I always mulch and my lawn mower doesn't pick up the leaves. It always keeps the leaves down, Its picking up the clippings. I haven't changed the blade yet. Do you guys think, changing the blade should make a difference with picking up the leaves?
I am a lazy guy so if this works, it will be a big help to me.
THank you
upupandaway
Probably... look at your current blade. On each end do u see it bent in 2 directions? if u want to collect leaves your blade needs to be flat then the end bent in only one direction. Replace it with such will solve your problem.
nj121
Thank you, do you have any recommendation for the blade.
Looking at the manual: its suggesting 942-0741-X
