Export thread
Troybilt Riding mower "Pony"
#1
J
jayreaser
I just was given this by a friend. She said it needs a ignition switch. The problem is I can get it to roll in either direction to get it to where I can work on it. It seems that both wheels are turning in different directions. Any idea's?:confused2:
#2
If gear drive make sure that the parking brake isn't stuck, includes the ones with a gas pedal engagement. It is a lever in front of the right rear tire. If hydro, make sure that the bypass lever on the back is working properly.
#3
J
jayreaser
Thank you I will check that also.:smile:
